ecu issues
  • Thread starter Thread starter Spoolin2g
  • Replies Replies 1
  • Views Views 757
Spoolin2g
Ok this has probly been asked a thousand times,but here it goes again. I have a 94 civic with a ls/vtec swap in it. its a b18a bottom, and a b16a head. it was running ruff one day and i took it to a shop, to check the cel, and the guy told me that i have the wrong ecu in the car, something about it still thinks it is a sohc motor and not a dohc. What ecu should i get or how can i solve this problem, thanks the noob
You should search this cause i'm sure it's been discussed alot. But for your car, i believe you can use a chipped p28 or an obd1 p72 ecu which came out the gsr. i'm sure there's more you can use but i'm to lazy to search it.
