i have a friend with a 99 hatch with a b18c5 that he races road courses on, here are the two setups he has run for road racing. 1st, he had the type r motor stock, with the exception of a jrsc on it, running at 4lbs. he put down 220hp to the wheels with that setup, and said he enjoyed it very much for the road courses. he has since turned back to na, wth leaving the bottom end with the stock type r components. as for the head, he did a full p&p with toda spec b cams, and the appropriate valvetrain. he has also put a set of twm itb's on there. he has not raced with this new setup, but those spec b's are supposed to be great for road courses.
