is there a swap guide on a 92 civic with a 96 f22b sohc vtec motor??
i know thats not the best motor and the vtec is totally different from a H or B series motor... but we got the motor for free with all the harnesse... everything... motor harness ecu and all under dash harnesse the ecu from the accord .. but thinking i cant use it becuase its obd2 being a 96.....i know i probally need to change some stuff around... fuelrail what size injectors iam i going to need... can i block the egr valve off completely? i dont have to worry about inspections being from SC
i am mostly worried about the wiring part,,,,
what ecu to use what harnesses to use
what axles to use...
any help is greatly apperciated and i not try to jack this thread
also the civic was an auto but wantting to use the f22b manny tranny
clutch res from the accord looks like it fits in but the pedla dose not...
so iam guessing i need to the junk yard and find a straight drive civic what years are compatible
for a 92? need clutch and brake pedals?
any speacil wires i need to get rid of.. throw out the tcu completely? if the civic even has one..?
