I replaced my friend's F22B2 with a F22B2. Easy swap. Engine already had the harness on it. When all was said and done, it fired right up. It runs well cold, and even partially to mostly warmed up, runs perfect. Once it is fully warmed up(10-15 minute idle) the engine cuts out at idle. Within a few minuted after that, it won't idle at all.
List of things done.
Changed spark plugs.
New distributor cap.
Different PCV valve
Changed over complete Throttle Body
Visual inspection of hoses.
This is killing my low supply of brain cells. Any comments appreciated!!!
Thanks
Different PCV valve
Thanks
