FS Civic & GSR B18C P72 swap parts head transmission linkage ecu parting out
  • Thread starter Thread starter mikaleg6
  • Replies Replies 43
  • Views Views 10K
how much for the p72 gsr head, is it assembeld and in working condition, also would that go on my b18b to make it a ls vtec.
The parts are all there. You will need to assemble it because the head studs are under the cams. That means you'll have to put the cams back on, and the cam caps. The valvetrain is all there. You'll need VTEC oil lines, head gasket, and an OBDI VTEC ECU (GSR if you wish to keep using the GSR manifold, or other if you plan to use a Skunk2/JG manifold). You might also consider some ARP head studs.
hey dude is the head complete? what is the milage on it ? and what r they specs
Post states: Stock OBDI P72 GSR complete head from throttle body, intake manifold, fuel rail, injectors, valve cover, cams, cam gears, valvetrain, and all sensors. Mileage is approx. 76k after rebuild. Ready for install.
Hey, I'm interested in the GSR head. Price shipped to 99216?
