h22a cam gear degree
  • Thread starter Thread starter DVJr84
  • Replies Replies 1
  • Views Views 961
DVJr84
H22A4drCivic
Hey guys im getting my timing belt, water pump, tensioners, etc. done on my jdm h22a and since im doing that ive decided to upgrade the cam gears to skunk2. The question i have is what degree should i put them? My internals are stock and i plan on doing turbo in like febuary on my stock internals. (Max boost for stock internals?) As for now I just want my car to run as good as possible for the stock internals. My cars mods are very minor. Dc sports header, exhaust and intake, chipped p13. Should i set them at zero degrees and is there anything i should look for since im having someone do this work???
I would set them at 0 degrees until you can get the car tuned since you really won't be able to tell if you're making power or losing power w/o tuning the cam gears on a dyno..
