Just like the title said, I rebuilt my lsvtec , B18a block , Gsr head. B16 p30 pistons new rings etc. Gsr head replaced the exhaust side valves tem seals, left the intake side alone. Piston rings were installed correctly. The piston chambers were honed, Compression was 200 on cylinder 4,cylinder 3 190, cylinder 2 195, cylinder 1 190. cylinders 3,2,1 were dry. Cylinder 4 had the wet plug threads had oil. I am still in the break in period. Only have 49 miles on it, At 30 miles I had to add a half a qt of oil. Havent done a leak down check yet got to wait till thursday. When the car is idling it smokes a little but when Hit the gas I get a blue smoke screen(a whole lot of smoke) Could anyone help. Thanx much appreciated.
