hatukazi
ambitious...but rubbish
I have a new problem, I just replaced the timing belt/tensioner on my rex along with new OEM plug wires and new NGK platinum plugs.
My distributor is from RichPorter Technologies (anyone heard of 'em?) and I think the igniter is shot. I came to this conclusion because I used to have a del sol and I had an (aftermarket) igniter go bad, felt just the same at steady cruise it misses and sounds like a subaru.
my dad says my O2 sensors are probably bad and I'm running rich which os causing the miss.
really both options suck but O2 sensors at $198 apiece is worse by almost $200, an igniter is $230.
So my questions are, when I took apart my distributor to try and replace my igniter with one from a 98 hx, they are way different and I cant ghetto rig them because the terminals are not labeled and tne shape is different. It looks like the igniter I got for my 94 sol, but I have heard that OBD0 and OBD1 dizzy's are not compatible any body know if I can use the same igniter?
Or if another distributor would work with my engine and ECU? (PR3)
also I need an IACV, CEL just came on today, which one would I order for a OBD0 B16?
I'm pissed cuz I already could have gotten a new engine from Hmotors with what I've spent to fix this and I'm about to fix it with a sledgehammer.
