hatch w/b16 wanna tuneup help..
  • Thread starter Thread starter Samuels
  • Replies Replies 10
Samuels
I have a 90 si hatch with a 1st gen b16 swap. I wanna tune it up but what car should I buy the parts for cap,rotor,plugs etc. I have'nt tuned this thing up and it could use it.
Should I buy 90-93 or 94-00 gsr parts?
99 SI??
Which car should I buy this stuff for?
The Si was only a sohc motor at 108hp I don't buy parts for that motor right?
So I buying parts for the 92-95 del sol SOHC Vtec. Would'nt it be better to use GSR DOHC parts OR 99 si?? I wanna get a cap,rotor,plugs,wires etc..
here ya go ;)
Water Pump 19200-P30-003 94 - del sol $86.28
Head Gasket 12251-P30-014 94 - del sol $57.56
Oil Control Orfice O ring 15142-PH3-003 94 - del sol $1.36
Intake Manifold Gasket 17105-P30-004 94 - del sol $8.26
Exhaust Manifold Gasket 18115-P30-013 94 - del sol $11.30
throttle Body Gasket 16176-PR3-010 90-91 integra $4.71
Pcv valve 17130-PM6-G01 94 - del sol $11.98
Timing Belt 14400-PR3-004 94 - del sol $48.72
Alternator Belt 31110-PR3-003 94 - del sol $7.56
Tensioner 14510-P30-003 94 - del sol $50.94
Thermostat 19301-P08-305 90-91 integra / 94 del sol (same) $11.69
Connecting Pipe O rings (2) 91314-PH7-003 90-91 integra / 94 del sol (same) $2.76
Cap & Rotor Assembly 06303-PR4-000 90-91 integra $24.54
Rotor (If needed seperately) 30103-PR3-016 90-91 integra $6.87
Clutch Cable 22910-SK7-A02 90-91 integra $45.54
Throttle Cable 17910-SK7-A03 90-91 integra $17.18
Cam Seals (2) 91213-PR3-004 94 - del sol $8.52
Oil pan seal 11251-P30-004 94 - del sol $18.64
Oil Filter 15400-POH-305 94 - del sol $4.93
Shift linkage bushing 54303-SB2-010 90-91 integra $4.66
crank seal 91212-PR3-003 94 - del sol $5.78
rear main seal 91214-PH1-004 90-91 integra / 94 del sol (same) $12.00
Valve cover grommets 90442-P30-000 94 - del sol $20.80
Spark Plug O rings (4) 12342-P66-000 94 - del sol $7.16
Rubber plug for exhaust cam tranny side 94 - del sol $4.00
Spark Plugs (4) BKR6E-N11 NGK $8.00
Upper Radiator Hose 19501-PR3-000 92 - integra gsr $14.71
Lower Radiator Hose 19502-PR4-A00 90-91 integra FREE BY MISTAKE
Bypass Hose (Thermostat) 19508-P08-000 94 - del sol $5.62
Washer for coolant drain on block 90401-PR4-000 94 - del sol $3.00
So does the local pepboys carry DOHC del sol parts?
And the 90-91 teg is that a LS or GSR?
wHAT ABOUT PLUG WIRES??
I was told by someone a few weeks back to use 99 SI parts saying it was basically the same motor any thoughts??
Will any of the stuff bolt up right, say a gsr cap,rotor etc. I would think it'd be better for peformance..
90-91 teg did not have a GSR trim. Get GS parts or 94 del sol vtec. Get GS ignition wires.
Dont buy these kinds of parts anywhere but Honda/Acura. anywhere else is SHIT!
:tisk: Pep boys whats wrong with you. This isnt't a Ford forum. We don't run around with hondaswap.com sticks on car thinking it makes them go faster (ok well some of us do, but I have dyno graph to prove it so :P ) Go to the dealer, did you see how cheap the parts were; the worst part on there was 50 dollars. If you can't afford that get a stamp and write to MTV. Maybe they will solve your problem :imstupid: :super: :mullet:
PS: just messing with ya, still its all about the H (go to the dealer). I think that list would make an excellent addition to the reference section.
