HELP!! FRANK MOTOR
  • Thread starter Thread starter JODYG35950
  • Replies Replies 3
  • Views Views 926
JODYG35950
I AM A NEWBIE AND NEED HELP. PLEASE!!!
I HAVE A B16A VTEC HEAD ON A B18A1 BLOCK. I HAVE THREE QUESTIONS:
1. WILL ANY B16 DOHC VTEC DISTRIBUTOR WORK WITH MY JDM HEAD?
2. WHAT IS THE GREEN 2-PIN SENSOR ON THE BACK OF MY BLOCK BETWEEN THE OIL FILTER AND ALTERNATOR?
3. IS THIS PLUG THE REASON MY CAR WILL NO LONGER GET FIRE TO THE COIL?
THE CAR RAN FINE UNTIL YESTERDAY, I CAME HOME SHUT IT OFF AND IT WILL NOT CRANK UP NOW.
0- lose the caps. its annoying as sin to read.
1- no. but it has little to do with the head- more so the electronics. match the dizzy to your obd of your computer.
2- knock sensor
3- totally un-related, but the car will run like ass without it
sorry bout the caps.
OK, here is what I got.
I tested my pickups in the distro and have good pulses out to ECU. Do not have signal back to ignitor. I have tried wiring with and without MSD. Is there any sensors that could have come loose causing the ECU not to fire the coil?
:D ok,
figured it all out. i had no fire because the fuel pump/ecu fuse in the dask was blown. i finally realized the ecu wasn't getting power nor was the fuel pump coming on. car runs like it did again. thanx for your help!!!
