IAC wiring for B18c NEED HELP
  • Thread starter Thread starter gsrjennie
  • Replies Replies 3
  • Views Views 3K
gsrjennie
ok, first of all, my ride is a 97 HB dx swap with B18c obd1. the swap turn out well, but the only thing i'm stuck on is code 14 from the check light. i know that my stock dx motor have a 2 pin and a 3 pin connector, and the b18c obd1 only have the 2 pin connector. what i'm i suppost to do here with the 3 pin connector? i use my dx harness. please, any info will be helpful. thanks.
THANKS for the info. i'll give it a try tomorrow. let me ask you one last question; ok, this is how i wire up the IAB: pink/blue wire to A26, the black to a ground. is this correct? it seems to run fine. and i'm running a obd1 P28 ecu. please correct me if this is the wrong way to wire it. thanks.
From what I know, sounds right. I'm not to schooled in the 96+ swaps, but that is what I have seen as far as info goes, and what I would do if I was wiring in a GSR.
