Im & Tb Match Question
  • Thread starter Thread starter HatchSpeeD
  • Views Views 695
HatchSpeeD
...Hi...
Will a d16z6 IM and TB fit on my EG dx motor?
I thought it may i just dont know what things i need to change like sensors or whateva.
If i get the IM/TB from a 16z6 with all the sensors and injectors...will it just simply bolt right on?
Thx for any help
Everything will fit fine, the map sensor and wiring are all the same, basically. The D16Z6 intake man. did have a rail/bracket of some sort that that the D15B7 didn't.
Find a D16Z6 IM with all sensors, tb, fuel rail, injectors, and the bracket. Look to pay about 65-75 shipped for it.
Yes if you get a Z6 IM it will bolt on to your B7. If you get a bare Z6 IM all of your sensors and Rail and injectors will work on it too. The one difference is in the throttle body, you may have the MAP sensor on the firewall, where the Z6 MAP sensor is on the throttle body, it still hooks up to your wireing harness, if you get a Z6 throttle body, and you can remove the one on the firewall.
