intake manifold maintenance
  • Thread starter Thread starter eg6sir
  • Replies Replies 7
  • Views Views 872
eg6sir
Supa Mod
VIP
i purchased a b16a3 manifold the other day and i was wondering how to clean out the inside...its filthy black...should i just have it hot tanked?...or buy somethin to clean it out myself.. :shrug2:
Quoted post[/post]]
Have it hot tanked and save yourself the trouble. (although I read somewhere that you aren't supposed to hot-tank aluminum parts.. I suppose it depends on what chemicals they are using)
I've done mine with warm soapy water and a bottle brush. Start by spraying it out with a can of carb cleaner to break up the carbon and the big chunks.
Quoted post[/post]]
That's some pretty good advice. I wouldn't worry about getting it squeeky clean. Just make sure to use some high-pressure water (like hose water from a nozzle) to completely rid the manifold of particles.
hey thanks guys...i'll try that...i was unsure about the hot tank...anyother suggestions..please post...
get it extrude honed/ported......or this is good
QUOTE(phyregod @ Sep 27 2005, 03:26 PM) *
how hard is it to just take out the intake manifold, because it sounds like it's not really that hard to clean, so if i can make it "breath a little better" without spending money.. why not.
Quoted post[/post]]
Because it'll cost you $40 in gaskets? Thats a good reason..
Quoted post[/post]]
Quoted post[/post]]
yea ...well i have it off already...i have to swap back to stock for referee...i got it cleaned...pretty easy..thanks..
