how much would a setup like that cost? i can't imagine it would be more economically viable than a supercharger or turbo kit.
guy on my local board has a J swap into his integra. another guy has one in his coupe.
seems pretty straightforward?
It doesn't sound as ridiculous as some, but straight forward isn't exactly the phrase for it at this point.
Mike, that's nice. Does the hood close without cutting, or trimming? Have you thought about the "other thing" we talked about?
Nice.![]()
How did you mate the motor to the trans? Adapter plate or does it bolt up?
Fits like an LS1 in a fourth Gen F-Body. Jammed against the firewall with miles or space behind the core support.
Yup, lots of room for goodies lol.
Tons of torque......you can here it when you are in and out of gears so quick. May be a dumb query but I'm interested in knowing if its the stock S2000 ECU running that motor or the stock J-series. Impressive numbers none the less.
Have you had a chance to test fit a stock hood?
Sounds and looks great. Is there a specific purpose for this build, or just something cool?
It is if you're swapping in the J block WITH the J transmission in a front wheel drive configuration. There is no longitudinal mount J engine setup from Honda. There are all kinds of things you have to deal with to turn the engine 90 degrees and get it to mount to a RWD transmission. Coolant lines have to be re-routed, the intake manifold has to be reversed, the clutch has to be figured out, the starter is another major issue that most people have no clue about- quite a few challenges compared to just swapping in an entire factory drivetrain.
I couldn't believe this so I searched it and you're right! I would love a built K24 swapped s2k. Now searching for s2k shells. Who will buy my del slo off me so I can start a new project?Lately I've seen a few K-Swapped S2Ks,
So is this something that other people are doing with their S2Ks now? Or are you really kind of pioneering this
Why swap a F2xC for a K? I thought the F's were better motors.
a few people have dropped in the LS1/LS3 blocks, but those have nothing Honda left in the drivetrain at all.
I think a few of the reasons are:Why swap a F2xC for a K? I thought the F's were better motors.
