That jdm h22a is in the honda accord euro R (tsx) and the prelude sir s spec. The motor makes 216hp. The. US h22 from 97 to 99 makes 190hp auto and 195 stick. And 2001 and 2001 each motor gained 5hp. 1992 to 1996 h22 made 190hp and was only a stick. MY SIS GOT A DEL SOL BUT SHE CAN'T DRIVE STICK SO I DROPPED A 94 H22 IN THERE WITH A 93 H23 AUTO TRANS. THAT SHIT MOVES.I purchased a jdm h22a a few months ago and i just read that the automatic h22a's only had 180 hp compared to the manual h22a's with 200hp. Is this true? If so, why would they be different?
look on the side of the block where it say h22a, it should have a ,1 4, or 5 at the end an h22a1 has 190 hp at the crank, at i think 98 it is an h22a4 which has 200 hp and 150 tq at the crank, the h22a5 which is the jdm closed deck has 220 hp at the crank, i believe its because the engine does not run as hot. If anyone has a jdm block that is not beat up pm me as i am looking for one, just want the bare block, thanks
wrong again lol there are 220hp h22wrong!!! My jdm engine just has h22. There arnt any 220hp h22's. They just came with 190 or 200hp.
wrong again lol there are 220hp h22![]()
thats what i have is a jdm h22 accord sir engine.........
my bad, thats just what i was told but thanks cause now i know and learn more every day but i try to help, even if the thread is old cause other ppl could be looking for the same info,
96 Si H23A1 swapped to JDM H22A with a converted OBD II to I plugged into a P13 ECU.
I was having problems with the MAP sensor wires, those were replaced today.
The car is still idling funny, backfires, VTEC does not engage, error code 3, and the RPM's get cut off at 6500. When the MAP sensor was unplugged the car acted like it wasn't looking for it. The idle did not change like it usually would when you disconnect the MAP. I tried 2 other MAP sensors and nothing changed. Used a voltage meter to make sure that the volts were around 5v.
Help please.
I should also add that the dizzy is new (well, refurb) as well as the spark plugs.
