Ok so I have a CEL on and I took the code off of it (blinking light) and it was 23 which is a knock sensor. My car is 95 civic and the CEL code list says 23 is for 96-98 civics...i'm guessing that's b/c usdm civics (92-95) didn't have knock sensors but jdm si's obviously did..also what about 99-00 Si's those have em too..
I was reading an article on a ls/vtec build in sport compact and it said that if the ecu throws a knock sensor code that vtec will be disabled..and mine is engaging fine (about 6000rpm). First off is this true? And if so how can i find out what is really wrong if it's not what the ecu says it is...
On a side note the knock sensor CEL suprised me b/c the IACV sensor is hooked up but the hoses to/from it are not..so i thought it would have been that...
Car: 95 civic, jdm b16a sir2, p30 ecu
