I know a 1996-1998 engine harness will work. Probably all the way to 2000 but you'd have to find someone else to confirm it. I wouldn't use any other year at all.
In terms of plug and play....worst thing would be you use some of the existing plugs on your motor's sensors and valves and splice them in to your new engine harness. If your motor is all OBD2...it should be plug and play.
You chassis is OBD2A and your ECU is OBD2A too. Did you get a 96-98 Civic engine harness? The engine hanress that came with your chassis would work fine. I'm guessing you have a different harness?
i just ordered the dx harness for my car it should be coming in soon.
Im changing all the wiring in my car. I realized i dont have to buy a adapter. Thanks.
I will be switching all the wiring sometime next week.
I installed the DX harness into my civic and all the plugs fit on the b18b1 except the Ivac plug. the harness has 3 wires when the ivac on the engine has normally had wires (2 contacts). what can I do about that.
