Ls Into Ek
  • Thread starter Thread starter hondsolo
  • Views Views 767
hondsolo
what mount do you use on the drives side when 96 LS into a 96 civic the one on top on T-belt side of motor
if you mean the mount on the top on the drivers side you use your stock civic mount, but you have to replace the s shaped bracket that bolts onto the block with on from a 99-00 civic SI. Get new studs while you are at it since its only like $15 and saves a big hastle
