I've finally made a decision about what to do to my car; boost it. I'm an all motor junky coming to the booosted world with hardly any knowledge so bear with me. I would like to run a stock motor on this and still make it reliable, I think it can be done. What I will do to prep is new bearings(main and rod), new rod and main bolts(OEM), maybe some rods if I can afford it, thick head gasket though I think my compression is low enough, and of course a basic fuel management system.(nothing expensive) As far as the type of turbo or how to build it, I'm lost.  So what I'm asking you to do is not recommend what I should do but tell me what to get and how to do it.(Any links, setups, pictures, etc will help) I'm looking to hit 200 at the wheels. I figure with that much I should be able to hit low 14's and keep up with the competition. I've heard of junkyard builds and have also heard it's quite easy to do them. Thanks and remember, make it as cheap as possible, but keep in mind reliabilty.
