NEED ENGINE SWAP HELP
REDRUM JOKER
I have a 95 accord,5spd with a F22A-OBD1-non vtec in it,I swapped a F22B-OBD2-vtec out of a 96 accord back into it. Im using the stock OBD1 harness and a OBD1 POA ecu. I know i have to run wires from the motor to the ecu for the vtec but i dont know where to run what! The other problem is the distributors are different and I need to how to wire the new one to the old harness!!! Iv tryd gettin help from everywhere and everyone I can think of so any help would be greatly appreciated!!!
you got to do a little more than that. there are an a lot more sensor's on an OBD2 engine. Check our tech articles on "how to wire vtec"
if you havent read it yet. before posting, search and check the references.
an easier solution would be to sell that 96 motor, and buy a 95 motor.
They're only about 300 or so bucks.
I would check into converting the motor to OBD 1. Use your stock harness, a 95 F22B distributor and injectors. That is, if they swap. I haven't done it, but that would be the easiest if the parts match up. That way you could stay OBD1 without an incredible amount of wiring.
Plan B would be a custom harness for the motor. Plan C would be figuring out the wiring yourself, which can be done with time and patience.
