K2e2vin
Well let me begin; on Monday/yesterday I noticed the heat started getting cooler; didnt think much of it. Today, I noticed the engine temp was higher than before; ok i need to replace thermostat.
Later on, my mom was driving it(I only drive it to work; my mom takes it back and I get a ride from a friend when I get off) and the car overheated like hell. I completely took out the thermostat thinking the old thermostat was just sticking close; nope! Car still overheated and the heater was cold(fluid was still full).
I changed the thermostat and flushed the radiator; ran it and noticed the fans werent coming on even though the thermostat was open. The fan has two motors; both run off of two relays(a high and lo relay), and the fuse was still good. I searched for radiator fans for the car and noticed they sell just the motors for it; two. Problem is, none of the fans came on. Do you think its some wiring issue or somehow both of the motors died at the same time? btw, a complete fan assembly costs $300(this will prevent me from getting my intake runners made...).
I can't use the CRXs because one; the front is just fucked(no headlights, intake manifold, throttle, etc. gone, etc. etc.) and the other CRX is without a transmission(god damn bolt broke with only 21lb-tq...) and rear trailing arms gone.
cliffs: Found out radiator fan is not coming on; hi and lo rad. fan relays look good, fuse is still good. What's going on????
