Newbie needing help with ls/vtec!!!!
  • Thread starter Thread starter JOSE DC2
  • Views Views 843
JOSE DC2
Could anyone help me with my ls/vtec motor build.
here is my setup let me know if i need anything more!
b18c1 head /ported & polished
CTR-cams & cam gears
CTR pistons
Injen cold air intake
buddyclub catback exhaust
goldel eagle vtec conversion kit
ARP studs & rod bolts
p30 ecu
GSR timing belt
ITR water pump & oil pump
adjustable fuel pressure regulator
310cc injectors
thats what i'm building so let me know if you guys have any suggestion i expect to make around 200-235 hp
Which intake manifold are you going to use? The stock gsr isn't all that great for ambitious projects such as yours.
sounds like a good solid build. i think 200whp will be a good goal for it. to get north of 220 you need more compression and bigger cams for sure.
also how are you planning to tune it?
