Originally posted by rudeludenotmeanthough@Nov 5 2003, 01:25 AM
To answer the ORIGINAL post, i believe your catalitic converter is clogged. My friends civic SI was having the EXACT same symptoms as you are describing. Try running your car with straight header (no exaust connected) and see if that solves the problem. If it doe, change the catalytic converter.
IT HAS NOTHING TO DO WITH THE FUEL YOU USE!
Do the simple test that i psuggested, and post your results.
Thank you and have a nice day.![]()
Thanks to all of you for the suggestions.......As for the fuel I will run 93 just to see if it helps any (I WILL CHOKE MY WIFE FOR IT)and as for the cat I will try it as well..
rudeludenotmeanthough: it does kind of make sense now becuause my car was running rich as hell for a couple days and it was blowing shit out....it was my IAT sensor......Does it sound like that could have been the problem.......
