A allmotord16rex Senior Member Aug 4, 2003 #1 If you are using a PG7 ecu on a ZC swap, can the PG7 be from an automatic?
Jeef NO MA'AM Moderator VIP Aug 4, 2003 #2 If your engine is an automatic. If its a 5spd you need the 5spd ecu. There is an extra sensor in the automatic ecu and the fuel curves suck.
