Please Help Me
aznhottiekj
im putting a 1998 integra ls motor into my 1998 civic cx hatch
will the wiring harness on my civic be ok??
i have the obd2 ecu,
and also will a 95 integra ls tranny work wit my 1998 ecu and engine??
thanks for the help
you will need to use your CX harness and probly lengthen a few wires (maybe not)
yes the tranny will work fine
the only thing remotely difficult about this is the o2 sensor. you need to conver the 1-wire of the CX to the 4-wire of the ls
for mounts- you need a couple form the 99-00 civic si. click up top- Swap - 6th gen civic for more info
