B - I had the same problem with my intake manifold. I just went to menards and bought a piece of 1/4 steel and cut out a small piece. Then I drilled four holes in it so that i could bolt it up to the manifold and to the bracket. I tapped the piece of steel for some bolts i had, but you could just use longer bolts and some nuts a guess. i also painted it aluminum colored. Good luck.
