Question>> About L3 Trans
  • Thread starter Thread starter ceehris
  • Replies Replies 5
ceehris
I have a D16Z6 in a 88 lx. I did not do the swap.
Im not sure if the person who did the swap used the stock tranny or
if they used a si tranny.
So my question is how would I be able to tell if it is the Lx tranny or a Si tranny?
you should be able to tell by the feel of the tranny. there is a large drop in rpm between 1st nad 2nd if you have the lx trans. i found that reikoshea has a sticky on this. you should go check that out when you find the numbers on your trans. it tells you the gear ratios of the trannies and what models they come in. i'll try to pull up the link.
https://hondaswap.com/reference-materials/honda-transmission-specs-29132/
that should take you there.
