i think ill bleed the coolant first, then if that doesnt help ill get some gasket maker.
whats the rule on different color coolants again?
dude, make it easier on yourself and check for a vacuum leak first... if you notice any change in the idle while doing it you know you have a leak..
and unless the car is leaking coolant from the intake the gaket is fine...check vacuum leaks my friend
you didnt try and bubble it out first.. :shakeshead: ...
