random engine cut out
  • Thread starter Thread starter 04elcblue
  • Replies Replies 3
04elcblue
have a 94 si with gsr swap and it just randomly cuts out. Does this sound like a bad dizzy or could it be ecu relay. some help would be good its my daily driver
I had this happen on my gsr swap. The valve cover gasket allowed oil to seep into the spark plug holes, fowling out the plug wires. A new VC gasket and plug wires did the trick. Pull out your plug wires and check for signs of oil. If that isn't it, it's likely the dizzy.
Yeah, more details would help alot. Can't expect anyone to pin point the problem for you with that amount of info. Start with the small things that could be causing it first, then work your way up. First I'd check to make sure you have a solid connection to your battery.
