Quoted post[/post]]
Ok, here's a thought, take it for what it's worth, as I have not separated tranny halves before. If you don't have room to get a screwdriver in there to pry, you might be able to get a metal drywall tapers trowel in between there to break the seal somewhat on the sealant. Use a small trowel, like 1". Or, If you're still stuck, it looks like those bolt holes bottom out. I could be wrong, I've only looked at the website, so double check. So, if you're very careful not to mash any of the threads, you can stick a pin punch into the bolt hole until it bottoms out, and then give it a tap. Use a pin punch that is half the size of the hole. You'll probably have to go around the tranny a few times, but that might jar that sealant loose enough for you to be able to pry it apart. Just be very careful of those threads. Make sure you are bottomed out before you tap it. You could wrap the end of the pin punch in some tape, to protect the threads. Good luck.
