im doing a dpfi to mpfi conversion on my 88 civic and i just need some info on the wiring. if anyone could direct me in the right direction that would be great. thanks.
depending on the swap you might need a injector resistor box. what exactly are you doing? d series, b series, v-tec, non v-tec? if you are just doing a mpfi conversion you need four injectors and im not sure if you need a distributor. if its obd 0 you need obd 0 injectors and distributor.
