swap D16z6 to b16b
  • Thread starter Thread starter eg95
  • Replies Replies 22
  • Views Views 3K
So I got the axels, dizze adapter, chipped ecu obd1. Do I need a throttle cable adapter plate? What motor mounts exactly do I need? And what stock mounts can be used? If you can provide a link to some that would be great... Thanks!!!!
if you want to run aftermarket mounts i HIGHLY recommend HASport :thumbsup: :thumbsup:
i suppose you could run a throttle cable adapter... they are cheap enough i just grabbed a new cable
up you you
