philyphreak2127
Back in the Game
The bolt holes on the throttle body didn't line up with the intake manifold correctly.
bump. i'll be using it on a y8 manifold. if anybody knows anything about it at all, please enlighten me. thanksi know a b20b and b20z are b series and should fit, but has anybody encountered any problems using one? i'm just wondering since they're not as ordinary as using any other b series throttle body. should it just plug right in like most other units? i have one available at a great price. thanks
bumpanother question. i'm probably going to be getting the gsr throttle body. will the throttle cable wheel, or whatever it's called, work fine? or will i have to use the one from my a6 throttle body? will they match up and bolt up perfectly? thanks
it's not going to make you any faster doing this 'upgrade' to your stock motor... you need supporting parts
those are fine - actually work really welli've used butt connectors that are heat shrinkable and have a kind of glue on the inside that protects everything from water and whatnot. i liked using those and would prefer them if you agree
