Tranny problems.
  • Thread starter Thread starter Spooner
  • Replies Replies 3
  • Views Views 937
Spooner
I put a zc in my car recently and had problems today. I was pulling out of dairy barn, I get to 3000 rpms, go to shift to second, there was a loud pop and I couldn't put it into gear...Pulled over, put it in gear, let off the clutch and the engine died. So I ask you, is this a tranny problem? if so what axles do I need for the zc tranny...and don't tell me 86-89. A guy tried that and it twisted and messed those axles up bad.
So, I need to know which axles work on the zc tranny, and if I need to change anything else to make the axles I need work.
URGENT! ANSWER ASAP PLEASE!
ZC transmission uses a ZC intermediate shaft and 90-93 Integra axles - you will need to remove the rubber seal ring from the outer CV joint where it meets the hub - pop right off with screwdriver
