transmission problem or clutch?
  • Thread starter Thread starter tphan4
  • Replies Replies 3
  • Views Views 925
tphan4
ok i have a 93 civic ex with a d16z6....the car already needs a new clutch because it is slipping but the other I noted that in third gear it will pop out when i floor the gas....now is that a transmission problem or will changing the clutch solve all my problems?.....a friend told me it might only because its lacking transmission fluid....neone else have same problem?
Its a transmission problem a clutch wont solve that. its probly the detents thats what holds it in gear.
so Ill replace my transmission and this will solve it?........will all d series transmission fit? What transmission is prefered for a turbo application in the long run?
