Vtec Bug?
  • Thread starter Thread starter Magana559
  • Replies Replies 26
  • Views Views 4K
to bad none of you VW lovers live near by, theres a HUGE VW junkyard right next to my dads shop.
Sweet Man Thats Hell Of Cool, Whats The Plan For It?
Something like this for the Bug.
And something like this for the Bus, but no this low.
Engine Adapters
They seem to do adapter plates but i cannot vouch for them.
Problem is I believe honda engines rotate in the opposite direction of the VW engine.
best guess is they just reverse the firing and custom map the ecu. I'm trying to figure how well the water pump and oil pump work in reverse though. I guess you can run those externally to the motor by an oil sump and an electric water pump. Then you have the tensioner that may cause some issues going backwards.
However I would not try this with a used engine, i would do it on a fresh build, there's the potential issue with wearing on the bearings because of the load being reversed, then again i cold be completely wrong.
Not saying Im going to, but it wou;d be sweet, if we were to do a non-VW sawp into the Bug it would either be a Corvair or Subie motor.
