wastegate install
  • Thread starter Thread starter zap45
  • Views Views 13K
zap45
i plan using a mbc with my turbo setup which has external wastegate i saw several ways of hooking it up. Here is a couple of ways of hooking it.
But on top of the waste is block off in one of the picture how would i hook mine wastegate with the boost controller
top goes to the boost controller
side goes to a vac source direct.
thats all that needs to be done.
if the top of your WG is blocked off, you might have to contact the dealer/parts guy for the piece that it needs.
what brand is it? looks like a tial...
you just gotta get the right fitting.
the source (in this case, fittin on the turbo) can be from anywhere. vacuum is vaccum.
