what compression is good??
  • Thread starter Thread starter shaneb
  • Replies Replies 16
shaneb
Would any one know what compression would be better, 8.81 or 9.01 or 9.21 for turbo on a b18c5 setup?
or a real answer:
depends on the turbo size, amount of power looking to gain, method of tuning, and streetability.
Originally posted by 97CTR@Feb 11 2004, 04:50 AM
poor ITR, being forced to run low compression. :huh:
No joke. This guy should sell his ITR if he wants to boost so he doesn't ruin a good all-motor engine. With the extra money he saves by buying a GSR he could afford aftermarket pistons and rods.
here we go again.... you gusy are hung up on the itr being impossible to boost. if hes got the walllet, its a perfectly fine chouce
I never said impossible. It's just impractical. And a waste of a purpose-built motor. Why not save money by making a wiser choice? :P
I want to use the itr for the type r cank,water pump, oil pump, ect. type r is alot better than the gsr or ls version.....i plan on geting it sleeved and rods.
And why is my question dumb ?
I thought 8.81 would be to low but at the same time i was told the lower the better.
Im new to the turbo world. I have a build itr that i would like to boost on whats. the big deal,
btw , are the skunk turbo cams good ?? any info would help alot!!!
the big deal is that the type r is built with higher compression as a high performance NA motor...
you take a type r and rip it apart and lower the compression to run boost then you should just sell the itr motor and get a gsr and use the extra money to build it...
yes but then u cant say u have a boosted b18c5 :P
still, the itr head outflows the b16 and gsr heads.
the crank is the same thing as a gsr's.
sleeving, youre going to replace the rods and pistons anyway.
so, whatever- its his choice, and 2k more for a slightly better flowing head, and a tranny with a crap lsd :)
ummm correct me if im wrong but dont things generally get lighter in order to make for better high revving
