Wiring For B20 swap into 92 hatch
  • Thread starter Thread starter D.R.Kinky
  • Replies Replies 1
D.R.Kinky
i have a 92 civic hb that came gsr... the block messed up on me so i swapped the gsr out for a B20... im almost done the swap jus need help wiring it back... can i still use the same wire harness or should i upgrade to what? also can i use the gsr ecu or wut ecu do i need?
yes use the same wiring, and no you cant use the gsr ecu unless you use the grs head on the b20 block
