MSD 8.5mm wires
NGK racing sparkplugs
B&M Fuel Pressure Regulator
port matched intake
70mm throtle body
Ported & Polished
5way angle valve job
JDM 4-1 Header
Pro Race Crank Pulley
RC 310cc injectors
ACT clutch
ACT Pressure Plate
Comptech Billet aluminum lightweight Flywheel (6.75lbs)
finl drive 4.7
im looking to get $5900 fot it.
here is some info on the motor
Full JDM b18c (dc2, ITR) Intake Manifold, Throttle Body, head ect..... then it was upgraded with:
12.1.1 Compression
Skunk2 Stage 3 Cams
JUN Titanium Retainers
JUN hi reve Valve springs
JUN Cam Gears
JDM LSD ITR tranny
OBD2 to OBD1 ecu JUN progam
Apexi V-AFC vtec controller
MSD 6al Ignition
MSD Blaster 2 coil
MSD Blaster cap
