Self adhesive carpet squares? Cheap and easy to install. You can make your own pattern and replace a portion if it gets water damaged or stained.
If you end up painting the floor make sure you prep it properly or it will end up failing. Go to a real paint store, not home depot if you do paint it.
Get some vct tile in a few different colors and make a nice pattern. The stuff is cheap and durable.
Yeah.
And I'm not going to lie. A mancave with no ladies once in a while isn't really that cool.
I mean who is going to use the stripper pole? James or Brian? Come on. No one wants to see those skinny fucks next to a pole. (jp homies)
:Word: make sure you clean/pre-prime/prime.
And by clean. Acid clean. And use oil based primer. Not latex. Latex won't stick well enough, even zinsser.
que?Tired of playing xbox on an LCD tv.
que?
Don't lie, you enjoyed Brian in that skirt over halloween.
can you get that U-Coat-It stuff at a home depot or Lowes? id like to do that to the garage (single car) of the house i will be moving in to. seems awesome, like a REAL garage floor. not just some dirty concrete.
I didn't look, but I'm sure you can. Menards always seems to be cheaper here though.
Anywho, I had my cousin and his friend tear up the carpet... it took them all of like 22 minutes to do.
I figured the concrete would be cracked and semi repaired, but it looks horrible. It's that rubber stuff to fill in the cracks, would that UCoat it stuff work on that or do you think it'd end up chipping it back up? I just don't really want to do this twice, but my cousin and Greg both say it should be fine.
