MI 1991 civic bully built and boosted!!!300+whp
Discussion in 'Vehicles: For Sale/Trade/Wanted' started by 91civictsi, Mar 9, 2009.
  1. 91civictsi
    91civictsi New Member
    1991 honda civic si
    b16a1
    301whp on a mustang dyno.
    motor
    endyn RW FI pistons
    eagle rods
    honda berings and thrust washers
    honada oem gaskets
    new water pump
    new oil pump
    b16 head
    all new seals
    ferrea super alloy valves
    crower cam gears
    arp headstuds
    brand new dizzy moded for msd.
    GSR trans
    quaife lsd
    walbro fuel pump
    fuel pressure regulator
    3in thermal exhaust
    hassport mounts
    turbo setup
    rev hard turbo kit
    garret .60A/R
    rev hard manifold
    intercooler pipes
    front mount
    tial 38mm wastegate with dump tube
    greddy type s BOV
    greddy turbo timer
    turbonetics manual boost controller
    other
    hondata socketed ECU P-28
    MSD 6 series ignition/ 2 step and launch control
    autometer fuel pressure gauge
    autometer boost gauge
    momo stering wheel/hub
    sparce seat
    harness
    kenwood radio
    new aftermarket speakers
    new battery/ converted to rear
    new upper and lower ball joints
    new outer tie rod ends
    all energy suspension bushings
    energy suspension shifter bushings
    traction bars
    brand new tires
    lots of other things im sure im forgetting ill add more to the list as i think of them.
    the car just got a brand new thermostat and coolant temp sensor.
    new exhaust gaskets.
    new headlight bulbs.
    and a oil change.
    extras
    2 tires
    energy suspension shifter bushings NIB
    2 sets of cap and rotor NIB
    extra dizzy has bad coil
    the car has alot of money into it and i have every receipt for it.
    if you have any questions feel free to ask them.
    im looking for trades or 6500obo.
    trades can include car for car, my car plus cash or your car plus cash.
  2. efhondakid
    Akron-Canton, Ohio
    Underhood pics? Dyno sheet?
  3. austin20110
    austin20110 New Member
    Northern Va
    I dont think your going to get 6K for that, but yea underhood shots and a dyno sheet would help with the sale
    gl
  4. |Chaz|
    |Chaz| Well-Known Member VIP
    It's definitely clean on the exterior, gotta give him that much. Underhood shots and dyno sheets would be nice though.
  5. 91civictsi
    i will post underhood shots and dyno sheet tomorrow.
    and just so everyone knows i have a receipt book of a literal 15k in parts for this car
  6. 91civictsi
    the only one i have for now.
  7. teamjdm239
    teamjdm239 professional driver
    lil pakistan, 239-florida
    lol at the dyno sheet, so youve had this car boosted for 6years? and i guess you swapped in a b16a1 after dyno? it sys b16a (two totally different hp specs)
  8. get_nick
    Washington State
    nice little car. not the normal shitbag noob post.
  9. teamjdm239
    noob post huh ? how is this a noob post? this guy seems a little shady , so i just pointed out a few things.
  10. get_nick
    Washington State
    re-read my post there ace.
  11. Z6CRX
    Z6CRX übber ɐɾuıu etarip
    Pittsburgh, PA
    i don't think he was referring to your post.
    its at least well laid out
    but it is suspicious he only has 2 posts and its a 6 year old dyno, but leaving the 1 off of a b16a1 can be a mistake but 6 years is a huge gap. Which is why you test drive and make sure of receipts. Cause if and when it blows, if those are legit, you go after him. He did state it was the only dyno pic he had at the moment though.
  12. 91civictsi
    sorry it was not supposed to have a 1 after b16a.
    yes this car has been boosted for 6 years.
    there is 35k on the build.
    205k on the body.
    i will have tons of more pictures as soon as the weather gets warmer.
    the car has not seen snow in 8 years. it is stored from November till April every year.
    im sorry if i seem shady to some because im a newb on here, i understand because im am the same way with the newbs on the other forums i am on.
    but i will get you any and all info or pictures you need.
  13. eg6sir
    quite n00b... you realize people refer to obd0 b16's as b16a1's sometimes because it was the first gen b16
    and yes, you're a n00b
  14. get_nick
    Washington State
    i wasn't calling you a noob. i was giving you props for posting a legit add. it was broken down just fine and had pictures/location/price. most people are just like, "i have a ef hatch, text me an offer" and thats it.
  15. Z6CRX
    Pittsburgh, PA
    Post up your username to the other forum your from and people will take it a bit more seriously.
    Holding up for 6 years boosted is pretty good, along with the mileage is great.
  16. 91civictsi
    my user name on xceedspeed is 91civic_tsi
    user name on civic 4g is 91civic_tsi
    if i do not sell this in a month or so it will be turned into another project.
    either a boosted k20 or make my ef AWD
  17. 91civictsi
    receipt book.
    i am going to try to take some more pictures of the car today.
    1 person likes this.
  18. get_nick
    Washington State
    i would consider putting a stock motor in there and parting out your turbo setup. you could probably get $3-$3500 for it with a stock engine and $3-$4k for the engine parted out.
  19. 91civictsi
    i would do that its just money is tight right now since i lost my job.
    witch is the main reason why it is for sale.
    i just cant afford 3 cars right now.
    if i get a job tho then this will not be for sale anymore.
  20. get_nick
    Washington State
    file for unemployment
