1996 Integra Build (B18B1)
Discussion in 'Auto Multi-Media' started by Xanatos, Mar 29, 2015.
  1. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    HMO sells JDM 92-95 H22 motor/trans/ecu (200hp) for $2200. If your set up is in good running condition, I think the price is fair.
    I have a hard time not telling you to keep it and swap it into your Integra instead. Oops...I just told you. H2B and rippin' 12's on and ECU, tune and slicks
    I figure you'll get someone wanting just the motor or trans (probably motor).
  2. Xanatos
    Xanatos Village Idiot VIP
    Florida
    If I hadn't invested as much in my b18b1 I'd seriously consider it. One of my favorite integra builds is H2b boosted, but like I've said this is the first project but definitely not the last. However the k20z has me seriously thinking about a K series build next. Or J swap for the frankenstein look and to challenge myself with the fab work.
    All that said I'm currently salivating over Rx7 FDs... so far out of my price range as a 19 year old kid but SO COOL.
    I sourced a GSR transmission that needs synchros from a buddy of mine for 250$ and I found out my best friend (RSX guy)'s dad is pretty good at rebuilding honda transmissions so I'm super excited about that. I know the LS transmission leaves a lot of power on the table if you're not running really high psi (and especially N/A, which it might stay for up to another year)
    ALSO: Whats a good wheel setup for performance/handling? I'm getting tired of low and slow. The stage 4 cams that I want suggest a specific size tire diameter and I'm guessing I should just roll with that, my rotas are 15x8 can I keep those or is another size "more optimal"?
  3. Briansol
    15x7's and 205/50 are the way to go IMO guessing a 205 on an 8 would stretch it too much. finding 215's would be togh. 225/45's maybe, but rubbing?
    really, it's more about the tire. if you're going to hit a ton of power, you're going to need something sticky like a drag radial or toyo r888 up front or you'll just spin 5 gears
  4. dilbeckskate
    dilbeckskate infamous
    Kennesaw Ga
  5. Xanatos
    Florida
    @Briansol I have a set of LS meshs with really nice tires.... I wonder if I should just clean them up and put them on there for the moment. Obvs get a set of slicks for the track eventually
  6. Briansol
    i think the width on those is 6" so you'll probably want a 195 on those. 205 might get floppy.
  7. Matts96HB
    Matts96HB . Moderator VIP
    I had Falken Azenis on my car - good grip for the money but don't expect them to last long at all.
    Jeef likes this.
  8. get_nick
    Washington State
    Briansol likes this.
  9. dilbeckskate
    Kennesaw Ga
    This kid can get a fd, they go for sale for under 10k all the time, at 19 my mod budget consisted of cone filters and self tapping screws and zip ties and no muffler with the hood off
  10. Xanatos
    Florida
    So, just curious why would I want the 404s over turbo cams? I was talking to a friend that explained a lot of stuff I didn't completely comprehend but it made sense. He said that turbo cams spool the turbo faster because of something to do with pressure in the cylinders and how it gets let out
    This is where I have next to no idea about anything haha
  11. CAFROG
    NOR-CAL
    A variety of NA stg2 cams have been known to get serious gains on turbo set ups. I'm not sure about 404's (B probably does) but I thought they could be considered to be similar to a stg2.
    Cams, springs, tune and GSR trans is a nice bump for sure. I've seen LS w/GSR trans get off the line quick.
  12. Briansol
    turbo cut cams are generally higher lift, near stock duration.
    all motor cut cams are generally higher lift, longer duration.
    fact is, people are making sick power on all motor cams on their turbo cars. the numbers don't lie
  13. Xanatos
    Florida
    So that raises a question to me while I'm running it N/A obviously the stage 4s would give me a sick N/A bump but what about the turbo cams? For example the stage 2 turbo cams from crower, how would that change my N/A driving?
  14. CAFROG
    NOR-CAL
    I'd really go with a NA cam. They're known to make you power now and later on with turbo.
  15. dilbeckskate
    Kennesaw Ga
    I agree n/a cams then turbo with them , much more agressive cam profile
  16. Briansol
    without the compression needed to be effective, a large cam and low piston won't be a winning combination...
    the turbo adds effective compression.
  17. Xanatos
    Florida
    Well I'm gonna have to pull the head apart soon to fix the valve seals. I let it sit since last thursday and I started it up and revved to the 4k rpm launch redline and it bellowed oil out the back until it cleaned itself out. My plan was to build out the head when I go to do the seals so I need to come to a decision soon-ish. But I likely won't have money to boost it for at least another 6 months and in that time it'll be n/a but I'm still gonna want to beat on it. Would the 402t's perform better or worse than the 404s with the low comp pistons N/A
  18. Briansol
    they will probably make similar power. the 404's won't be able to perform to their potential despite being 2 stages higher. you'll also need vastly different tunes to accomdate the fuel burn with extra the air moving in.
    ultimately, don't worry about being 5-20 horse off your na build. focus on the end-goal and buy accordingly, or you'll spend more twice.
  19. Xanatos
    Florida
    I dont want to put a cam in it and make it borderline undrivable until it's boosted though thats my main concern. I think both cams will lead me to my end goal but if the turbo ones have more of a stock cut i think they might make it run out smoother until i reach that "end goal". That's really my main concern, maybe I've been articulating this wrong :/ i feel like we've spent a lot of messages running in circles because I can't convey what I'm trying to
  20. Briansol
    it will drive fine. it just won't make proper power without the compression.
