axle nuts!
Discussion in 'Civic and CRX - EF' started by HondaElite, Nov 5, 2008.
  1. HondaElite
    HondaElite senior member
    fall river.mass
    ok mines are like f^%$en welded idk..i tried a breaker with a pipe! and it broke the dam breaker bar?! wtf?! is goin on?! can someone please give me an opion please? idk whats left i can do....:(
  2. 91_stylin_civic
    91_stylin_civic Member
    New Jersey
    an impact gun should take them off, ive broken a few breaker bars myself but i had no problem with an impact gun.
  3. HondaElite
    fall river.mass
    ill try it..i was surprised a breaker by itself usualy does it but i guess not this one lol...thanks though
  4. phyregod
    phyregod !!YTINASNI
    Central Texas
    Second on the impact.
    Also, did you unbend the stake?
  5. HondaElite
    fall river.mass
    yea i used a pipe with the breaker bar and bent the breaker bar and broke it! ive never done that or delt with one that crazy tight..but im gettin a impact gun tomorrow so fingers crossed thanks..and yes i took ou tthe punhed in piece
  6. reckl3ss
    reckl3ss New Member
    New York
    This happened to me, impact gun didnt do it. I even went to my mechanic and we used the most powerful impact gun he has. still didnt work. you need to get the nut RED hot, the whole nut needs to be red then use a impact gun. After I did that it popped right off.
  7. HondaElite
    fall river.mass
    thats what im gonna have to do cuz i tried my friends impact gun he works at chevy..8 or 900 foot pounds didnt move it! dam basterds on there if i got to im goin to have some one cut the nut with torches its frustrateing already..thanks for the replys to guys i appreciate your input and ideas
  8. hondacivicguy05
    hondacivicguy05 New Member
    Rome ga
    try taking and air chisel to it i had the same problem also and i took the air chisel to it and finally got it off just be careful with your hubs if you if you use the air chisel
  9. efhondakid
    Akron-Canton, Ohio
    Ive never had problems getting them off, Ive taken few off with having someone on the brakes and a big wrench. :dunno:
  10. phyregod
    phyregod !!YTINASNI
    Central Texas
    I've had hell with one or two, and I've broken a breaker bar..
    One fool proof method that is dangerous as hell (do at your own risk, good chance of catching shrapnel) is to get a strong ass breaker bar, get a 4 foot cheater bar, have one person pretty much hang on the cheater bar with all their weight, then whack the crap out of the breaker bar with a 3-5 pound sledge (6 inches to a foot from the nut). Over and over. Its like an impact wrench on crack. That will break the nuts loose 99% of the time. But like I said, do it at your own risk.
    Also, if you go to a tire shop that works on big rigs, they can remove any nut on planet earth. Those people have gnarly breaker bars with 15 foot cheaters.
  11. efhondakid
    Akron-Canton, Ohio
    And the inch drive impacts with 938498 lbs/ft of torque.:D
  12. unknown6329
    unknown6329 New Member
    i had the same problem the driveshaft would just not move at all (we impacted it,used a breaker bar, used a torch )and nothing worked so what we did was we removed the upper and lower ball joint and removed the outer tie rod end from the spindle and we took off the whole thing wheel spindle and drive shaft included and we just traded it at a junk yard for another spindle .worked for us
  13. redxcobrax
    redxcobrax God member
    Kenosha, WI
    Once again, did you unbend the circular ring thing? It's called the stake I guess? It's the ring around the nut with a little "v" chaped bend in it towards the nut, you need to bend that out.
  14. HondaElite
    fall river.mass
    yes i did..i said i did thats why idfk whats goin on so im jus gnna take the whole spindle to the machine shop and let them get them off what ever wat possible idc how
  15. reckl3ss
    reckl3ss New Member
    New York
    I tried chiseling my but off once. piece flew off hit me in face. the next day I put a magnet to my face and my face was magnetized. needed to go to the emergency room to get it out.
  16. redxcobrax
    Kenosha, WI
    sorry for not reading right. that sucks dude.
  17. t3t4delsol
    t3t4delsol New Member
    York, Pa
    go buy some PB blaster. spray it on then try it again
  18. 94H_Ex
    94H_Ex Under employed
    Florida
    Make sure your Impact gun has some nuts to it too. My impact turns 450 ft lbs of torque, and i dont have a problem in the world, but not only does the ft lbs matter but your air volume and pressure. My air compressor pushes 250 psi's, so that helps it alot more. Good luck
  19. D16SiHatch
    D16SiHatch New Member
    pushes 250 psi's...? alrighty then.. lol. its not just the max psi your tank can store but for how long it can maintain that high number when using various tools. bigger tank with more volume, and the larger compressor the better.
  20. HondaElite
    fall river.mass
    well ive been lazy and i still havnt got em off..i tried pb blaster to btw and it didnt help :bangdesk:...im just going to have someone cut the nut off with cutting torches..ill let you guys know if i get them off
