b20 vtec???
You're back on a topic you know nothing about. You really need to research. I don't even want to help you anymore. So many retards read about a couple peoples builds and how power is controlled by XX psi of boost.then come on here and ask if they can make XXX hp on XX boost.
Kid you need to just research. You really, really need to do a lot of reading. Start with the basics and work your way up.
yup, they're real paper weights, make shit for power, shit for torque, no aftermarket support, the trans that's mated to it is also garbage, the entire setup is better off as scrap.
here is the list of all honda engines list
https://hondaswap.com/reference-materials/honda-engine-list-29128/
B20A2 & B20A5 have a bore of 81mm ..... so its a B20 with a 81mm bore... ? :mellow:
exuse me if im wrong of course .... :)
Technically you're correct, yes, but most people don't consider those part of the Honda B-series engine family, because...well...read what Blanco and 92civicb18b1 posted about them....
