Back on the ground...
Discussion in 'Other Vehicle Discussions' started by Airjockie, Apr 22, 2009.
  1. Airjockie
    Airjockie Watanabe Whore!!!
    Meriden, CT, USA
    Off the jack stands finally, and outside to let the rain wash off the dust...
    and larger pics here... Another 260Z
    74 260Z
    Fresh rebuild....
    5 speed swap
    new reverse switch
    ACT HD pressure plate
    ACT 6 puck Disk
    New Clutch Slave cylinder
    New Stainless steel flexible Slave hose.
    Nismo 2 way LSD
    R180 diff 4.11
    Rear disk brake swap
    JSK Rear Disk Brake brackets.
    fresh disks.
    New Hawk rear pads
    Rebuilt 240SX calipers
    JSK 270mm Wheel spacers
    ST huge sway bar
    Tokico Illumina's
    ST 1" drop springs
    Larger front brakes swap
    Toyota 4X4 calipers
    fresh cross-drilled and slotted rotors
    fresh Pads
    New 15/16 Master Cylinder
    JSK 270mm Wheel Spacers
    ST huge sway bar
    Tokico Illumina's
    ST 1" drop springs
    Wheels:
    17x7 17x8 Volk Racing Ultra C's
    215/45 225/45 Falken 512's
    Still left to install:
    New Fuel System
    Triple Weber 45mm Carbs
    New Canon Intake.
    New Carter Fuel pump.
    New Fuel filter.
    New throttle linkage.
    Fresh MSD 6AL
    Roll bar
    Race seats and harness.
    Interior.
  2. ASG14
    ASG14 New Member
    Stamford, CT
    NICE!!!!! Can' t wait to see this done!
  3. get_nick
    Washington State
    are you still working on doing the rb swap?
  4. TurboMirage
    why is it lopsidedddd
  5. Airjockie
    Meriden, CT, USA
    define lopsidedddd?
  6. TurboMirage
    the left side sits higher than the right side.
  7. Airjockie
    Meriden, CT, USA
    that's the drive way runoff...
  8. Airjockie
    Meriden, CT, USA
    In the fall, when the snow start's, the car will go on the rotis, and get fully rebuilt with more awesome parts... RB, Cage, widebody, new frame rails, sick welding parts, sick wheels, and everything my next year's income tax return can afford...which will be around $7000:ph34r:
    For now, I just want a fun DD and summer car...:p
  9. TurboMirage
    when did your driveway get that bad lol
  10. hosmer
    B R I D G E W A T E R
    when'd you get the other 2 volk's?
  11. Airjockie
    Meriden, CT, USA
    That was a set that I snagged last year that nobody wanted to buy..
    I'm still looking for a pair of 17x9 CE-28's to match the othe rpair I have...
  12. awptickes
    MD
  13. TurboMirage
    i wanted to buy the volks. they dont fit over my brakes though.
  14. awptickes
    MD
    Yeah, probably because they're the only wheels clayton has that are 114x4.
  15. TurboMirage
    you only know that the mirage is that pattern because i told you yesterday ;)
  16. Airjockie
    Meriden, CT, USA
    they are 17" they fit over everything...:rolleyes:
  17. awptickes
    MD
    Nah, I knew it was the Mirage pattern from a long time ago, you always complain that he doesn't have any mirage sized wheels.
    It's also the pattern for the 4-lug BMWs.
  18. TurboMirage
    nope, wrong!
    the OEM mirage bolt pattern from 93-02 is 4x100. only the 89-92 is 4x114
    front hubs are 4x114 EVO3 and rear hubs are 4x114 GVR4. yes, lots of combinations of parts on the car ;)
  19. Airjockie
    Meriden, CT, USA
    the ultra C's are 4x100.....
  20. TurboMirage
    which is still no good since i wanted the biggest brakes i could without moving to 5-lug.
