Done building my STI now onto my new toy
Discussion in 'Civic and CRX - EF' started by versus1ss, Dec 7, 2010.
  1. versus1ss
    versus1ss New Member
    Ft. Hood, TX
    So i recently bought a 1990 crx si (salvaged) as my latest project car. i had to replace the front fender and trunk. I will eventually have to replace the front and rear bumper as well as the front bumper beam the was bent. I just bought some Blades to put on it and will be looking to do a motor swap leaning towards an h22 my homie has one in his civic hatch and me likey. I know most dont think its work it but im just looking to put i/h/e and thats it. As far as the cost and the hassel its no biggie.
    Im a pic buff so here are some pics of the crx
    Red= Not purchased
    ????= not sure
    Occupation: CPT in the Army
    Car: 1990 CRX Si
    Interior:
    Sparco Torino
    Sparco Carbon Fiber Pedal set
    Autometer Carbon Fiber Gauges- Boos, Oil, A/F
    Karcepts Shifter Mounting Kit
    Exterior:
    Color: Pearl White or java black pearl not painted yet
    Custom license plate: Tri Me
    Carbon Fiber SIR Hood
    Carbon Fiber low hood scoop
    New Front bumper, L&R fender and Hatch and rad support.
    J's Racing Front Lip
    Rims, Tires and Brakes:
    GSR Blades painted BBS Gold
    Potenza RE-11 fronts
    DA front brake swap
    ARP Extended Wheel studs
    Skunk2 Black open ended lugnuts
    EBC Yellow stuff pads
    Track Rim and Tires: ???
    Handling:
    K-Tuned Traction bar w/ Stablizers
    Neuspeed Sport Springs
    Tranny:
    Built 6 spd Tranny w/
    Quiafe LSD
    Frana 1st & 2nd Street Dog Conversion 2.93 and 1.95
    GearSpeed 3-6 Carbon Syncros
    ClubRSX 4.052 Final Drive
    Exedy Twin Clutch and Flywheel
    Extra Stock 6 spd Tranny
    Extra used ACT stg 2 Clutch
    Engine managment:
    KPRO
    Engine:
    K20a2 Swap
    Twin Screw Lysholm AX1600 blower by JMercado
    JR Manifold and associated parts
    Conversion Plates for the Twin Screw blower
    Custom Intake Plenum
    Aftercooler for manifold
    Custom manifold fabrication and CNC machine work
    JR Bypass Assembly
    Blower Pulley
    Aftercooler Heat exchanger
    Rule Pump
    All parts necessary for all system
    HAsport Mounts
    KPRO
    Rywire Conversion Harness
    Karcepts A/C and P/S Removal Kits
    K-Tuned 4-2-1 Header
    RBC w/ Adapter Plate Selling
    RSX Base Axles
    84 GTI Radiator
    Rcrew stg2 cams w/ vtc cam gears, supertech valvesprings and retainers
    Custom Intake
    extra set of lifetime warranty AAP axles
    1000cc ID
    Hybird Racing FPR w/ Lines and guage
    K Swap Headers
    Karcepts Themostat Swivel neck
    Custom Exhuast-Kteller 3" Piping,
    Walbro 400lph FP
    Spark Plugs BKR9EIX
    Hondata 4 Bar map sensor
    Some Clutch hydro conversion
    M&H SLicks
    Front Drag rims
    Oil Catch Can
    Possible batery relocator
    and whatever else i get the iche to buy
    INSERT FINISHED PIC OF CAR HERE ------>
  2. versus1ss
    Ft. Hood, TX
    oh and here are some pics of my STI and the build list.
    Engine:
    Dominator 3.0XT-R Full Ball Bearing Turbocharger
    Draco turbo blanket
    Custom CP Pistons 100mm
    Eagle Rods w/ARP 2000 bolts
    GSC Stage 1 Cams
    Brian Crower Valve Springs and Retainers
    Brian Crower Valves
    09-10 STI Nitrided Crankshaft
    Cosworth Bearings
    ARP Head Studs
    Mild PNP headwork
    SSAC FMIC
    Grimmspeed PnP Intake Manifold w/ Spacers
    Grimmspeed PnP Headers
    Grimmspeed Hi-flow Crossover pipe
    Grimmspeed Top Feed TGVs w/ deletes
    Tial 44mm EWG and Grimmspeed uppipe
    SSAC TBE
    Draco 2"x50" exhaust heat wrap
    Perrin Top Feed Fuel Rails
    1000cc Injector Dynamics
    Walboro fuel pump
    GMS Radiator with hoses and high temp thermostat
    GMS Turbo inlet
    Perrin Pulley
    Perrin EBCS, Hallman Manual Boost Controller
    Perrin MAF
    K&N Cone filter
    Ixiz Concept Air/Oil Separator W/ Crankcase vent
    NGK 1SC Spark Plugs
    Turbosmart Dual Port Bov
    Turbosmart Fuel Pressure Regulator-800
    Karboy Battery Tie down
    GRUPPE-S Hood Dampers
    New STi Gaskets kit
    Misc: Water and Oil Pump, Timing Belt Tensioner
    Engine Management:
    Cobbs APv2
    Turbosmart e-boost2
    Transmission:
    ACT HD Street Clutch
    ACT Streetlite Flywheel
    AP Short shifter w/ Kartboy shifter bushings
    TIC 6MT Pivot Bushing
    Suspension:
    BC Coilovers w/ rear extenders
    Whiteline Steering Rack Bushing
    Whiteline FR Swaybar adj 27-29mm
    Whiteline RR Swaybar adj 24-26mm
    Karboy FR & RR Endlinks
    Kartboy Endlink Spacers
    TIC/ Kartboy Rear Klicky Kit
    TIC Killer Klunk Kit
    Kartboy Transmission Cross Member Bushing
    Group N Engine/Tranny Mount Combo
    Tein FR Strut brace
    LiteSpeed Rear Chassis Bridge
    Exterior:
    Ferrari red paint job- Rosso Corsa 322 D.S.
    Tinted Windows 30% Front & 5% Rear 3 Windows
    Limited V-Lip
    Headlight Painted Flat Black
    Debadged
    5 Perrin Wing Stabilizers
    Rally Roof scoop w/ functional vent
    Pillarless mod
    Kartboy Front License plate delete
    Hella Horns
    Interior:
    HOT WIFE in passengers seat(Priceless)
    Recaro all Black leather front seats off EVO9 MR w/Wedge Eng. mounts
    Black WRX rear seats and door cards
    Sparco Red 3” 4-point camlock harness w/ shoulder pads
    Kartboy Black shift knob w/ red logo
    HKS Turbo Timer
    Redline blk w/ red stitching shift boot, e-brake cover
    Stri gauges: EGT, Fuel, and Oil Pressure
    Defi Boost gauge
    Beltronic STi Diver Radar Detector
    Pioneer AVIC-D3 Indash NAV/DVD
    Zenesis ZN-502 Alarm
    Wheels and tires:
    Rota SVN 18 by 9 on Hankook Ventus V12 evo K112 255/35
    Brakes:
    Stock Brembos
    Hawk HPS Front & Rear Pads
    Built by:
    William Warren of Percision Werks
  3. kelsodeez
    kelsodeez New Member
    bay area, CA
    pictures of priceless wife plz.
    good project. its gonna be ALOT of work. good luck man.
  4. versus1ss
    Ft. Hood, TX
    here a decent pic of the wifey but dont ask for more
  5. versus1ss
    Ft. Hood, TX
    sorry for the different fonts i cut and pasted mostly and fyi this isnt my first honda i owned a crx si and an accord back in the days. i bought my first crx for 200 bucks and this for this one i only paid 500. i love inexpensive parts compared to parts for my sti
  6. versus1ss
    Ft. Hood, TX
  7. TurboMirage
    STi needs more EVO.
  8. versus1ss
    Ft. Hood, TX
    Sure there buddy
  9. TurboMirage
  10. double0Si
    double0Si ლ(ಠ益ಠლ) VIP
    Columbus, Ohio
    I think it has just the right amount of Evo.
  11. eg6sir
    What kinda numbers the STi make?
  12. dilbeckskate
    dilbeckskate infamous
    Kennesaw Ga
    I think its got VTEC yo ! haha damn its a good lookin car bro, good luck
  13. Taco15
    Tallahassee Fl
    you would say that.:)
    good project man! can't wait to see the process.
  14. dilbeckskate
    Kennesaw Ga
    I want your halo eyes headlights for my rex.... sell the Subaru and do a sick boosted K-swap in the rex, it will love you long time ><
  15. TurboMirage
    thats just stupid. AWD > FWD.
  16. versus1ss
    Ft. Hood, TX
    well i have 2 crank sensors left to replace so they can finish the dyno that was started but it should be 630hp at the crank and on the mustang dyno around 420whp on pump and around 520whp on race gas.
  17. versus1ss
    Ft. Hood, TX
    i dont think ill ever sell the suby especially after the 20k i spent on parts. The K-Swap would be nice but you really cant beat 2g's for a stock 200hp motor swap. Plus i already have 2 turbocharged cars...My STI and my Wife's Twin-Turbo BMW 335I (i have already installed dual intake's and will be doing a ecu upgrade for aditional 80-100whp:cool: in the beginning of next year)
  18. TurboMirage
    how many crank sensors does it have????
  19. versus1ss
    Ft. Hood, TX
    2 and i ment to say cam seneors....Why cant i edit on this forum
  20. TurboMirage
    you needed to go blue first i think. which you are. edit button is on the bottom right side of your post.
