dpfi to mpfi ecu help?!?!
cardinalboy07
im doin this conversion but on my ecu clip slot b10 and b9 r empty not b12 it has a wire in it..what do i do?
also im using odb2 injectors so there is no resistor box what do i do with the wires tht are suppose to go there?
this is the set up
d16y8 head and mani
d16a6 block
odb1 dizzy (92-95)
odb0 to odb1 conversion harness
odb2 injectors
now correct me if im wrong a1,a3,a5,a7 are for injectors....
c1,c2, is for dizzy crank positon sensor..
IF you have no resistor box inline then you take all 5 wires and connect them. Otherwise you will have no power to your injectors. I know it sounds weird but that's the way it is done.
If your using newer injectors they get ran directly to the ecu, no resistor box. A little less wiring. You can still use the 2 inj. wires in the engine bay for the 1st and 3rd injector, you'll have to run 2 extra wires for 3rd and 4th injector. Read the write-ups.
