K2e2vin
Originally posted by E_SolSi@May 31 2003, 02:22 AM
the rotary engine is not a 2.6, 3.9, 857857.7, or anything else its a 1.3
it doesnt matter how you want to try to justify it
oh but it makes 3 compressions for every revolution
all that means is that its a more efficient engine design than the standard piston engine
it doesnt ingrease the displacement
what is the general definition of displacement? total volume of air/fuel that an engine can draw into all of its cylinder in one cycle right? look at it this way; when one of the chambers is at the combustion chamber/area, the other chamber is drawing in air/fuel.
an example that many people use is (mostly about the small displacement honda engines) the motor wouldnt even 2-liter bottle. so if you take a b18c; make it suck up water instead of air/fuel mixture. turn the crank two times because the 4-stroke cycle is two revolutions and you will notice it will suck up about 1.8Ls right? now do the same with a rotary(13b) engine, but turn the crank once b/c its full cycle occurs in one revolution. you will notice the engine will draw in about 2.6L.
