Fuel Pump not priming
Discussion in 'HYBRID -> ED-EF / DA' started by halefyr, Dec 8, 2008.
  1. halefyr
    halefyr Junior Member
    Long story in short form,
    B16 swap in 89 hatch, friend wrecked 89 hatch, swap put in 91 crx....
    I don't have fuel pressure, at all....no prime at start up....zilch
    Main relay is good, ignition is good, wiring seems good, fuses good, ecu PR3 seems good, gives code for coolant sensor (6 flashes)
    Has not had fuel pressure since wreck, car was flipped and laid on roof.....
    Any suggestions would be greatly appreciated..
    Thanks
  2. dacheat
    dacheat ..is grounded.
    strongbadia
    holy crap and a free bump for you. :eek:
  3. t3t4delsol
    t3t4delsol New Member
    York, Pa
    inertia switch, its a small button located in your trunk that disables the fuel system.
    1 person likes this.
  4. LILBLKCRXSI
    LILBLKCRXSI New Member
    :roll: swap put in 91 crx
